Hewlet Packard..
the local computer store has a 50-50 chance of being able to help..
While Hewlett may already know about the issue..The hard part is finding some one there who will help you!
Results 31 to 37 of 37
hey, just an update, so far my comp is working and has yet to freeze, what i did was oppened error checking scan in properties/tools of the C: drive, i ran the error checking scan and selected automaticly fix errors and such, then i had to restart my comp then when my comp started the scan took a little more than an hour!!! Now after this error scan, i have yet to recieve a freeze, i hope that i fixed it. Also i set both my dvd-rw on master end of ide 2, and dvd-rom on slave end of ide 2 both on cable select, and both drives work fine, just a little slower when both are used at the same time, that is all!!! I will keep an update if my problem has been solved or not!!
One last thing, i emailed hp support and have yet to recieve even a reply, I hope they can reply so i can see thier prospective of the problem!!! -
dang, the problem still exists!!! I was running dvd2one to record a dvd but my comp froze yet again!!!!!
I want to add that when i have my computer on it's side(computer horizontal) that i have yet to recieve a freeze!!! When i have the computer at normal position(virtical) then i recieve the freeze often! Example, i was tryng to burn a music cd-r with nero, i had the computer virtical and tried to burn the same cd twice, and both the times i had this freeze at the same exact point when making th cd. Now when i tried to burn the same exact cd, i had the computer on it's side(horizontally) and the computer didn't freeze at all!!! Now could it be a power problem? Loose Wiring? What can it be!!! This is really a big problem now!!!!!!!
Could you be having heat problems? Maybe you're getting a better airflow when your computer is on the side versus vertical. It's a longshot I know but if your CPU is getting too hot that could cause your computer to freeze until it cooled off.
that can be a possibility, but then again, i can just turn on my computer and it would freeze when i run programs at times!! This is a very disturbing problem!!!!!
well i tried to email HP support about my problem and it has been over two weeks since i emailed then, i even sent them the same problem letter twice. So Tip Don't expect a reply with HP Support!!!!
any software that can be installed on an external hard-drive or USB stick?
By lee09 in forum EditingReplies: 4Last Post: 8th Sep 2011, 09:01 -
What type of hard drive do you have your o/s installed on?
By johns0 in forum PollsReplies: 11Last Post: 21st May 2011, 18:31 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Replaced defective Drive (O:) Installed New HD and Can't Rename it (O:)
By cplevel42 in forum ComputerReplies: 8Last Post: 16th Oct 2009, 11:25 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 09:25
