What can I say?It won't install.I install all the components.Then I try to open the app.and it bounces and quits.If it helps the mpeg2 encoder is a text doc. and it's all located on the desktop. PLEASE HELP!!!
Matt
Results 1 to 12 of 12
okay, I take it you are trying the installer engine to install the various components etc?
the mpeg2enc file should not be a text file. use the terminal to change the name like:
mv mpeg2enc.txt mpeg2enc
then run the installer for this again. I think the installer then copies the file into the proper location which i think is /usr/bin/mpeg2enc
otherwise you can look in that directory using termnal and remove the .txt from the mpeg2enc file if it has been copied there already.
have another read of the install instructions also to make sure you have all the required compnents.
I hope this helps.
markus
Didn't work;No such file or directory
I also tried downloading it again, but it again opens with text edit. Any other suggestions, or should I just get 42?
Matt
42 can not do all the things that ffmpegx can do, personally I gave up on it. try it if you think it fits your purposes.
mpeg2enc always downloads as a txt file, you need to then rename it removing the .txt extension using a terminal window.
If you are using the ffmpegx installer engine, it is really straight forward if you follow the directions. download the three files as specified.
To rename mpeg2enc you must start a terminal window and type:
cd Desktop/
then
then use the installed engine to move and install it to the correct location.
Still not working. Please just send me your copy of mpeg2enc to mtnbording@aol.com
thanks,
Matt
It doesn't sound like the problem is your copy of mpec2enc. it sounds like you aren't renaming it and installing it properly.
have you got all three files you need to download? (the links are in the installer engine)
just having another copy onmpeg2enc will not allow it to work if it isn't installed in the correct locations. it just won't work.
give me more information about the steps you are following to install it.
markus
I can get it to change the name from .txt to .nothing but it's still a text document!? Here's what I tried:(ignore that no such file or directory I messed up)
Welcome to Darwin!
[localhost:~] matt% /usr/local/bin
/usr/local/bin: Permission denied.
[localhost:~] matt% /usr/local/bin sudo chmod 755 mpeg2enc
[localhost:~] matt% cd Desktop/
[localhost:~/Desktop] matt% sudo chmod 755 mpeg2enc
Password:
[localhost:~/Desktop] matt% mv mpeg2enc mpeg2enc
chmod: mpeg2enc: No such file or directory
[localhost:~/Desktop] matt% sudo chmod 755 mpeg2enc.txt
[localhost:~/Desktop] matt% mv mpeg2enc.txt mpeg2enc
I have no idea how to work terminal (as you can tell) so hopefully you can help me out.
thanks,
matt
I have all three downloads. (The new versions)
Also, if it helps I'm running 10.1.5
Sorry to waste your time. But any way that wasn't my fault. Check out macupdate.com
http://macupdate.com/info.php/id/8988
Matt
XP Installations. Big problems.
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 9th Mar 2010, 09:43 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 22:19 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 10:02 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 11:00
