I'm used to my DVD Decrypter, DVD2ONE and RecordNow Max method...ifoedit looks interesting but looks too complicated after reading some sample uses for it.
What I want to know is that if you rip the .vob files from a dual layer movie and its under the 4.7gb size...why does DVD2ONE make it even smaller instead of just keeping it the same size and just adding the files needed to burn it.
Did you remove any audio streams or subtitles
The DVD2ONE do not compress the file if it is smaller then 4.7 GB,but,if you remove streams of audio the file will be smaller by the size of the removable staf.
Miki
Ahhhh yes...i usually just keep the DD5.1 sound and no subs...so thats why its smaller? It's not really reducing the image size, just the fact that im keeping only one audio track and no subs? cool...thanks for the info.
How to compress files?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2010, 11:42 -
1,5 miniDV (20gb) to DVD disc (4,7gb) compress
By etnies in forum Video ConversionReplies: 1Last Post: 19th Nov 2009, 10:34 -
reducing large avi files to 4.7Gb disks
By aquergunk in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2008, 07:19 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52 -
How to Shrink 7.7 GB VOB files to 4.7GB DVD on MAC?
By mc80 in forum MacReplies: 5Last Post: 30th Mar 2008, 09:41
