I'm trying to capture a long movie with virtualdub and huffyuv which creates large files. My HD is formated to FAT32 so I have the 4GB limit. To avoid this I set up a spill drive and set the limit to 1900MB per file. Now virtualdub creates two files at 2GB and then one file at 200MB and stops. I can't figure out why? Any suggestions on how to get vitrualdub to create a many files as it needs until I tell it to stop.
Check under CAPTURE ---> STOP CONDITIONS.
Sounds like the capture is stopping because its limited in some way. I usually know the time of my source material. I use the "capture time exceeds" options and enter the correct number of seconds (plus 60 seconds just to be safe).
wway
Cannot get MTS files into virtualdub.
By jtl999 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2012, 22:41 -
Weave deinterlace plugin for Progressive Segmented-Frame videos(After Effec
By Stears555 in forum Video ConversionReplies: 1Last Post: 8th Feb 2012, 16:20 -
Output Files in VirtualDub
By Deter in forum EditingReplies: 9Last Post: 18th Jul 2010, 21:01 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 08:13 -
Help capturing segmented streaming video
By keitachan in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2008, 12:49
