How do I create a dolby digital 5.1 SVCD file?
So far i can create great SVCD and DVD compliant files, but not I need to know how to do 5.1 sound.
Please, someone
Alfonso
Do some searching...but to give you the skinny...5.1 in SVCD not possible, only in miniDVD format.
Multichannel 5.1 MPEG audio is offically in the SVCD specs, but it is unlike that your hardware setup will support it. Making such a thing isn't that easy either.
Dolby Digital 5.1 (AC3) is not supported in SVCD.
DTS (5.1) is not supported in SVCD.
Thus, for SVCDs, stick with plain Dolby Surround encoded stereo. DD5.1 is an option with miniDVD if you have a stand-alone player that supports this.
Regards.
Michael Tam
w: Morsels of Evidence -
Well, I would like to encode miltichannel on SVCD, but I'm also planning on getting a DVD burner by the end of december (pioneer). So I also need to find out how to do it for DVD.
At that point I'll still be creating SVCDs for my relatives.
My Apex can play DVD compliant mpeg2 files just burned to the CD at 80% the standard DVD rate (about vbr 6000), which works for small clips perfect.
Alfonso -
Like he said, mpeg-2 multichannel is not only a long process but likely unsupported by your hardware OR your relatives hardware...but if you are getting a DVD burner..why would you not make DVD-Rs (I assume) that contain ac3 5.1 surround instead mpeg-2 surround??...which Apex do you have, playing a mpeg-2 compliant file is different than playing a vob file with encoded ac3 audio?
Hi folks, what is the problem?
This link will te;l u everything!!
http://www.labdv.com/en/examples/svcd_audio.htm -
This link will tell u everything!!
thanks for 2 wasteful posts, we have already said everything that is contain over there at Labdv
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 15:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
