    Apr 2001
    I want to be able to make menu pictures without having to spend hours with a graphic application like psp. What I'm looking for is an application that can take the pictures I have extracted from the movie (with VCDEasy for instance) and insert them into a menu template (like thumbnails), which I then save as an ordinary image and convert to a mpeg still. No need to manually rezise, cut and paste the pictures and insert "hard coded" text. I now use VCDEasy to make my menus and chapters (superb software, I must say :P ).
    Have anyone heard of such a program? Please tell me. I have searched this site and the web but without any luck.
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Why are you doing all of that converting and re-converting anyway? just take a screen cap, then import it into whatever authoring software that you use.
    Also, Nero (among others) will let you use any frame of the movie/clip as a thumbnail in the menu.
    I think you have made this more complicated than it is.
    Apr 2001
    Ok. I get it. But I can't make chapters in Nero. That's why I use VCDEasy. But VCDEasy can't make menu pictures and that's why I have to make them manually.
    Netherlands
    Why don't you use Ulead Movie Factory!!!! It does support VCD/SVCD/DVD.
    You can also import background music....
    Jan 2003
    Munich, Germany
    To create such menu pictures I am using the freeware Digital Picture Index Creator Version 0.9.2. You will find this software at http://www.cd2html.de/dpic.en.html.
    Jürgen
