i have encode a movie to xvcd file size 868 mb,i want to wright it with nero ,i have 878 mb(100min ) cd's ,and nero ask me if i want to overburn
i say yes ,he start to burn ,at 100% he says done and after that he saysthat the cd is not completed succesfully is this normal or did i do something wrong,please can somebody help me ,and why nero ask me to overburn if i got 878 mb cd's ,thx
The question is does the drive support that size CD Blank??
Most drives are 650Mb, or 700 Mb burners.
If your drive does not support the large size blank cd it won't work. Nero will say completed but it won't work.
Or it could be that the drive (Player) you are putting the disk into can not handle that size disk.
More details would help. But first check your burner specifications. Check the specifications on the drive you are trying to read in.
Hope this helps.
Cheers -
where can i see the burner specifications ,thx,the video works but the sound don't match with the characters mouthOriginally Posted by TBoneit
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
