  1. I'm a MEGA Super Moderator Baldrick's Avatar
    I'm now working on a new "guide link-system" for all guides(both for guides on our site and other sites). A bit similiar to our other lists on the site.
    - The guide links database will include a subject, a brief description of the guide, what tools it uses, who made it, the link to the guide, latest updated (only when I update it in our list, I will probably not check guides on other sites if they have updated it...) and a forumlink to where you can discuss the guide. (also how to category and how to subcategory so I can list them in my how pages)
    - You will be able to list all guides on one page for easy searching.
    - You will also be able to search guides that uses a specific tool. If you for example search for virtualdub you will get all guides including virtualdub.
    Any more ideas are welcome to include in the guide database.
    the page with all guides will look something like this
    https://www.videohelp.com/guides
    Mar 2002
    canada
    well iv'e barely had any sleep in 30hrs,but from what i can see,it looks like a great idea
    Most is done...now I only have to spend some days adding guides.
    The "layout" is not yet finished...but it is very easy to change later. I can also add more columns to the database later if anyone would like some extra info that I have forgot.
  5. I like it baaldrick! keep up the good work man
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    You can now search by tools and by author
    example:
    https://www.videohelp.com/guides?tools=15&Submit=Search&madeby=-1&howto=1
    but I have lot of work left...to add all guides and fix the final layout.
