Hi
Im trying to convert a divx file to Mpeg 2 for dvd. Im using TMPG, but it keeps freezing at certain parts of the movie, but the audio continues. Is this because of bad frames, and how do i overcome this. If there is any guides on this issue, pls post a link as i cant find them, on the site.
thanx
I had the same problem, Turned out I had Divx5.02, Upgrading to Divx 5.03 cured it.
It could work for you too.
Good Luck -
If the DivX has bad frames, TMPG will barf. Check the DivX for bad frames first.
Use VDUB and select 'Check for bad frames' or DivXfixTo Be, Or, Not To Be, That, Is The Gazorgan Plan
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
Can't stop DVD from playback
By maverickluke in forum DVD RippingReplies: 7Last Post: 18th Jan 2011, 03:52 -
How do I make Mencoder stop converting 3 - 10 files at once?
By gemasis in forum Video ConversionReplies: 3Last Post: 29th Dec 2008, 16:56 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
Freezing DVD-R
By markannab in forum Authoring (DVD)Replies: 7Last Post: 3rd Feb 2008, 04:01
