i dont know if there is a guide for this or not but anyway
what is the best way to fit lots of tv episodes on 1 cd in cvd format while keeping the qulity pretty good or is it just what you think looks good
I would have to say that you really would have to have very little quality expectations if you want to fit a bunch of episodes on a CD. I don't think this is the answer you probably want to hear but you best bet would be just to try stuff and see what works best for you.
It would also help if you clip out the commercials as well. You can figure about 8 minutes of commercials per half hour of recording to clip out. -
I generally fit a 1 hour show/CD (that's roughly 44 minutes). You can use SVCD or VCD, it's up to you. CVD is very similiar to SVCD bitrate wise. If you want to fit 2 hours worth, dont' bother, it will look horrible.
What's the source, Capture card or DVD? It really, really matters (noisey capture drives the bitrate through the roof).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You can easily fit a 40-45 min series episode in one 800MB CD, using CVD as target format.
The bitrate is about 2100 - 2400 average, depanding the lenght of the episode.
If your player support -x- formats like xCVD, then you can succeed amazing results by going beyond CVD top bitrate standards. For example, 1000min, 2300 average, 3600 maximum, gonna give you prety good quality with 1/2 D1 (xCVD or 1/2 D1 DVD)
Unfortunatelly, this is -X- for and CD based format, but if your DVD standalone can handle it, it might be the best solution you have!
It is very good solution also, if you own a DVD-recorder. For most television stuff, the 1/2 D1 CCIR-601 framesize is the best solution IMHO. -
the clips are just ones that i have downloaded from kazaa and they are about 40-45 mins long
tim, you can download my CVD template in the Tools Section to your left!
:P
Then all depend from the source.
CVD is good only if your source is good and with a framesize more than 352 X 576/480.
If your source is lower, then better make vcd (or xvcd). You gain nothing by going more!
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 23:19 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09 -
Extracting Episodes from a DVD9
By Firewire60 in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 17:44 -
4 episodes to 1 disk with svcd2dvd help?
By charlie_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jul 2007, 05:12
