Pinnacle Systems has released the first update of the DVD transcoding software InstantCopy. The 7.01 version has the following list of bug fixes and changes:
http://www.pinnaclesys.com/docsupport1.asp?division_id=1&langue_id=2&product_id=1153&p...opy&page_id=62
Version : 7.01
Date Inserted : 12/3/2003
Extension : exe
AUDIO_TS folder is added for compatibility issues with various stand alone players
- Volume Label on destination disc (editable in customize disc dialog)
- Layer break on copied DVD gets removed
- Fixed problems when removing sub pictures and audio streams
- Fixed problems while creating overlay fixed (SID Error)
- Fixed problems with parallel writing to multiple CD Burners
- Fixed rare burning error "Buffer not found (x)"
Advanced registry settings:
USES THESE SETTINGS WITH EXTREME CAUTION NO SUPPORT CAN BE GIVEN IF YOU CHANGE DEFAULTS OF THESE SETTINGS
HKEY_CURRENT_USER\Software\VOB\CD Wizard\7.0\Copy
DWORD "DVDAnalyzeMaxRel"
Defines video size that gets analyzed in percent (Default: 7%)
DWORD "DVDAnalyzeMinAbs"
Minimum video that is analyzed (Value * 2,5 MB)
DWORD "DVDSaveQuality"
Defines the place reserved for not predicted video size in percent (Default: 6%)
STRING "DVDHideConversionPicture"
"True" Hides preview picture while converting and analyzing a DVD (Default: "False")
STRING "DVDAlwaysEnableOkButton"
"True" Always enable OK button in "Customize Disc" dialog even if the predicted size is over 4,32
STRING "DVDRemoveLayerBreak"
"False" to disable removal of layer break
