Hi,
I burn mpeg to cdr or cdrw but the dvd/vcd player doesnt like it.in other words it will not play it.any help would be
very helpfull...thx
You can't just burn the MPEG file as a ISO data file to the CDR and have your DVD player read it. Take a look under 'Author' to the left for ways to burn.
yea and Y not? Y would making an ISO of a VCD then burn the ISO to another black disk not work? An ISO is an EXACT image of the origionaL.
Computers -
yea and Y not? Y would making an ISO of a VCD then burn the ISO to another blank disk not work? An ISO is an EXACT image of the origionaL.
Computers -
He is referring to ISO in the sense of the ISO9660 standard for writing data files to a disk using a FAT-type 8.3 filesystem, not an ISO disc image file.
If you just start your burning software, select data CD, and drop your MPEG file into the filesystem, you are creating a data CD, not a VideoCD.
Like Vejita-sama said, read the authoring guides.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
VCD
By dodd22 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 18:01 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
VCD
By rocketboy in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 16:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
