I've created a few vcds and when I go to play them on my dvd player (Phillips dvd724) it does not play any sound. I have it connected to a reciever could that be my problem?
Search your player in the DVD player's list, and see if other users of that player have had the same problem. It might be that your DVD player does not support VCD. Try playing it on your PC, to see if it's a problem with burning the VCD (if you dont have any playing software on your PC look in the 'tools' section of this site). I'm not sure what you mean by a 'receiver' but try disconnecting it and see if it plays fine like that.
Matt
Which specific codec makes Media Player Classic play sound from DVDs?
By c627627 in forum Software PlayingReplies: 3Last Post: 24th Apr 2010, 11:23 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 19:00 -
Trying to play 5.1 surround sound using Media Player Classic
By pbuscher in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2007, 17:54 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 04:20
