Hi guys,
I just recently purchased an All in Wonder and was playing about with it last night, but had some problems.
I was recording clips from TV to MPEG-2, using my own custom profile to match Pal SVCD - i.e. 480x576, 2.6mbps variable bit rate (modified to this exactly using Stinky's MMC Reg Editor), and 44.100 KHz 16-Bit Stereo sound.
Once I'd saved the clips I was then dropping them straight into Nero and creating an SVCD with them. I got compliance warnings but chose to ignore them.
Anyway, basically the video looked fine, but the audio didn't sound great and worst of all was going horribly out of synch (there were no gaps in the audio though). However, I didn't seem to be dropping frames when recording.
I ran the diagnostic software that comes with the card and it told me that DMA was not enabled and my sound card wasn't performing well enough (< 2%??) - I'm using the onboard sound on an Epox 8RDA+
Could it be either of these problems causing the lip-synch or is it something completely different? Can anyone recommend any good guides for the All In Wonder (all the ones here seem quite dated).
Thanks in advance,
Bob
What version of MMC where you using ? Only MMC 7.7+ have the a/v sync fix and SVCD support.
I'm using 7.9. I've now started using IUVCR and this appears to have solved the problem.
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 07:27 -
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 19:27 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:10 -
Cinematize synch problems
By whoisquilty in forum MacReplies: 4Last Post: 5th May 2008, 18:34 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 22:22
