Still working on this but though a small flare to a possible problem is in order right now.
Basic observation:
Cant prove it solid yet but when you install IC7 on a system with Studio 1.06 and a DC 10+ card, IC7 affects the system to the point of crashing or rendering the DC10+ card as if it died.
Since I keep Drive Image copies for that system just in case of problems etc. I notist after installing IC7 demo but did not realize something was amiss. When I started AVI_IO it came up with a black screen but would capture ok. Studio also had a bit of a problem but worked. Received the full version last week and deinstall the demo and installed the new one. About the same problem but would start acting to the point of not working sometimes then get to the point of total failure of the capture with inverted colors line setc to where it would totaly lock up the card.
Restored back a working image of the boot drive and all works as it always has. Installed IC7 seem to be ok. Reboot and slowly the problems return including the crashing.
Working on some more test but wonder if anyone has this combo and experence the same problems? Have a friend with S8 and a DC10 with the same type of system and may set up a test and see if its just a 1.06 Studio vs IC7 or also in Studio8.
Results 1 to 1 of 1
Pinnacle studio 14 problem with DVD export
By Alternator in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2010, 21:22 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09 -
Video Studio 9 SE problem
By eclipse95 in forum EditingReplies: 0Last Post: 9th Aug 2008, 17:41 -
Studio 11 Ultimate problem
By ingeborgdot in forum EditingReplies: 12Last Post: 14th Jan 2008, 14:53 -
Problem With MPG files in Studio 9
By BillP2 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 06:49
