Well i was wondering y in my portable audiovox y some dvd-r would play ok and some would stop and squeal thru the whole movie (know most of u dont remeber the first post) but i notice something.... all my dvd tht i burn and put a cvr on it is the ones thts having the problems..... its squeals real hard first then finally in the middle of the movie or near it begins to start stoping and starting again.... my question is does dvd cvrs cause play back problems.... so far its only in my portable player.... also i use the dvd covr thing from best buy where u stick the paper on this little round thing and it sticks it on there perfectly.. Can it be something with the ink tht i am printing with from my canon???????
I take it you mean you are adding a sticky label on to the top of your DVD's. My guess would be that you are making the discs too thick for the sapce in your portable, hence the sticking and squeeking.
yea... the ones tht sticks on the top/// i looked at it and tht dont like the problem.... the paper is so thin how could tht happen???? also even witout the covers its start out screaming but then after a while it kinda quiet out a little but its not as quiet as a regular dvd. Would it have anything to do with the lazer reading it or anything?????
My friend... you really didn't see some of my earlier posts right ??
The labels REALLY make the discs impossible to read, not only in my standalone players but also in my Sony dru500 drive.
THIS IS A FACT !!! and i'm possitive of that.
If someone as no problems with labels I wonder what they do for that to hapend.
.. and yes.. many people had the same problem as I and you.
DO NOT LABEL !! -
thts crazy...... how about some of these other dvds tht i rent tht have covers on em and run well in my dvd player ????
Are those paper labels or stamped ink (do not know the words) ??
The "original" movies do not have a PAPER label !
Anyway try what you want, experiment everything... one thing i'm 100% sure: ALL the dvds that I label wont work perfectly anymore, with others not labeled (same brand, same burning process etc) I have NO problems !! -
yea they are paper ones... some matte paper some glossy.... so how is orginal dvd players front stamped on????? and i am not sayin you are wrong because i got some more dvds tht i have been experimenting with and same thing happens to all of them so right now i have chilled puting the front on them until i find out whats up.... my thing is (AND SOMEBODY PLEASE ANSWER THIS) Y does paper covers mess up dvd play back????? thank god its just in my portable.... my onkyo, ps2 and xbox works fine
but the f part is i use my portable alot at work..... so i need to find a solution to this
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 18:28 -
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Issue getting burned dvd-r to play in Sylvania portable dvd player SDVD8727
By deviant_delusion in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2010, 19:02 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
