I have a DVD that I want to copy, but when I look at it in DVDX, there is onLy 1 chapter and it is a 950 MB file. So, I can't split it up and put it on a VCD like I want to. I am new to all of this, so is there a way to split it up when I encode it or is this just an impossibility to do? Also, I don't know how to use the search function here, I tried but I always get no results.
It's not an original, it's some tv shows that someone recorded onto a dvd. I bought them from someone and now that I have them I figured out that my DVD player won't play copied DVD's, only VCD's. So, I want to make some VCD's so that I can at least watch them on my TV. It's only 1 large 950 or so MB file though so I can't split it into chapters, and this is my first time at trying any of this so I really don't know what I am doing.
Matt
thanks,
Matt
Matt
on the left, in the green section, click on newbie. read a little. it won't hurt. trust me.
Thanks alot, I really appreciate people like you, you are so nice. I wish I could be just like you. Wow, what a guy. If only the rest of the world were so helpful. I know there is a ton of info on this site, but there is so much, for me at least, it's too much. I can't get started with this because I am having trouble finding the answer to this question.
Thank you so much,
Matt
how long is the movie? there are a bunch of ways to do it. you could encode to video using tmpgenc so the whole movie could fit on one cd but i don't know how long the movie is. if its under 80 minutes then great. some dvd players can't play non standard vcds. if it dose play non standard vcds and you would like it done fast then split the movie in half and burn. i normally use Ordix Mpack Professional (can get that at www.cnet.com )to splt and combine mpegs and i use nero to burn.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
Adding subtitles to a BIG Avi file and then burn to dvd(?)
By Hal05154 in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 15:15 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53
