  1. When I had windows 2000 installed I download the demo. Then bought the program and ever thing was still fine I was able to resive the movie and push it from 4.3 to 4.5 now with windows XP I can not movie the resive scale it's alway's at 100it just will not movie
  2. Oh ok I update IC7 and it still did not fix the problem. But I did find other fix set to customized resize. When you see "Customized disc" and Video preview audio and subtitles to the left you will see "Content's" and "Video track's" Title 1 title 2 and so on. Uncheck one of the title's like one in the middle like Title 8 or other one. Now the scale will go down to 63 or so. Now check the title back that you just uncheck now you can move the scale but the grenn bar does not movie. still. Movie it to where you want it then hit "F5" now hit oh ok. Under windows 2000 I did not have this problem
  3. It seem's that you can movie the scale but it still only 3.99gig other titles can be check that let you move the green bar. I do not know if this is a XP problem but I never had this problem with windows 2000
  4. The resize does not work on some Anime DVD's like cowboy bebop or outlaw star. With episode one being vob5 for the first 10 minute's and the second half of that episode is vob 2 very funk's DVD's to back uop seem;s to work fine with movie resizing
