  1. I have a couple of movies downloaded in Divx format, that have a couple of corrupt frames. I found a program called AVIFIXED that does a pretty good job of smoothing over the bad frames, but once I do that and convert it to M2V and MP2 using TMPGE, all of a sudden there is a watermark in the upper right hand corner. It is not there when playing back the "fixed" AVI file, only after converting. Has anyone else experienced this?
    If it 'aint broke, I can fix it.
    Melbourne, Australia
    If it's a DivX watermark, it can be disabled by using the 'decoder config' in the divx codec folder.
