I downloaded the Xvid version of The Two Towers and I want to convert it to SVCD so I can play it on my standalone. I used DVD2SVCD to convert it. The problem is that the finished product is out of sync. I even tried converting the audio to uncompressed WAV before I converted it to SVCD, but that did not help. Here is my log file if anybody wants to look at it:
WNASPI32.DLL 4.5.7.1008
- 3/11/2003 8:57:34 PM
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.1.2 build 1
Initializing
Initializing finished.
- 3/11/2003 8:57:41 PM
- Free on drive C: 14271.81 mb
- AUDIO Extraction
Audio extraction finished.
- 3/11/2003 8:59:43 PM
- Free on drive C: 14102.30 mb
- AUDIO conversion
Converting MP2 to WAV. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Program Files\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"C:\Program Files\DVD2SVCD\Movie\Encoded_audio_1.mp2.wav" "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Encoded_audio_1.mp2.wav" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.lo g" ) -ota( -g max ) -2lame( -e -b 192 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 3/11/2003 9:33:14 PM
- Free on drive C: 11940.00 mb
- Converting Pictures
Converting: C:\Documents and Settings\JIM E\My Documents\My Pictures\Two Towers.jpg
Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 3/11/2003 9:33:44 PM
- Free on drive C: 11938.73 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 2495536764
AudioSectors: 255577252
VideoPAPO: 34698168
ScanOffsetBytes: 302038
SeqAligningBytes: 19196167
DVDBytes: 0
VideoEndHeader: 12
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 900.00
PureMPEGStream: 2185763126.93
Seconds: 10506.91
CalcMPEGStream: 2185763126.93
Frames: 251698
CDSize: 800.00
Number of CDs: 3
Cut point 795.00
Variable Settings:
Frames: 251698
Anti Noise Filter: Off
Passes: 4
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 1664
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
AVISource("C:\DOCUME~1\JIME~1\MYDOCU~1\MYVIDE~1\TH ETWO~4.AVI",False)
ConvertToYUY2()
BicubicResize(480,276,0.0,0.6)
AddBorders(0,102,0,102)
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 0.940
Video Encoding finished.
- 3/12/2003 12:58:20 PM
- Free on drive C: 9760.41 mb
- Video Pulldown
Executing Pulldown. Commandline:
"C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\Program Files\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC.mpv" "C:\Program Files\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.m pv"
Video pulldown finished.
- 3/12/2003 1:19:05 PM
- Free on drive C: 7677.92 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\TitlePicture.bmp.mpg"
- 3/12/2003 1:19:26 PM
- Free on drive C: 7677.86 mb
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg"
- 3/12/2003 1:19:38 PM
- Free on drive C: 7677.80 mb
- 3/12/2003 1:19:45 PM
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mb
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
3490 Seconds
Offset in Seconds: 3492
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
3715 Seconds
Offset in Seconds: 7207
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
Multiplexing and cutting finished.
- 3/12/2003 2:01:43 PM
- Free on drive C: 5297.56 mb
- Determining length of audio
Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
3492.240 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
3717.552 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
3289.584 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
Analyzing finished.
- 3/12/2003 2:04:32 PM
- Free on drive C: 5297.55 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 58
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~1.XML"
- 3/12/2003 2:11:41 PM
- Free on drive C: 4490.97 mb
- No. of chapters to create: 61
CD image #2: CD_Image_File_CD2.bin
"C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~2.XML"
- 3/12/2003 2:19:30 PM
- Free on drive C: 3684.77 mb
- No. of chapters to create: 54
CD image #3: CD_Image_File_CD3.bin
"C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD3 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD3 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~3.XML"
CD-Image creation finished.
- 3/12/2003 2:26:48 PM
- Free on drive C: 2883.11 mb
- SVCD Creation finished!
Thanks in advance.
Closed Thread
Results 1 to 1 of 1
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
Problems with DVDFab when converting DVD TV episodes to Xvid
By ryangarfield in forum DVD RippingReplies: 3Last Post: 11th Oct 2009, 10:38 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
sudden vdub sync problems when converting hd sources
By uk_dan2k in forum Newbie / General discussionsReplies: 10Last Post: 8th Feb 2008, 16:37 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 17:19
