I'm trying to create VCD's for use on a standalone dvd player from Divx files. For some reason I can't convert from a Divx avi to a mpg file. I've tried using TMPGEnc and XingMPEG Encoder. Normal avi files work but Divx files come up with "source file in use or unsupported codec". I have the Divx codecs installed because the files play.(kscodecsv433). Can anyone help.
Yes, u need to use a program called avi2vcd. It does direct conversion from avi to a standard compliant VCD mpg. However, its simply a small point and click program and doesnt have any adjustable quality options or anthing speciaL, also, it takes much longer to encode with it then it does if u could use TMPGenc, unfortunatly the newer builds of TMPGenc dont support DivX
conversion.
http://www.mnsi.net/~jschlic1/
_________________
Computers
<font size=-1>[ This Message was edited by: Chris X on 2001-09-10 01:59:23 ]</font> -
chris, i am afraid you are innacurate in your description of tmpgenc....using the latest "j" version, i just tested it to convert a divx to vcd and it has started the conversion fine
i even stopped the process, viewed the created file and it converted up to that point well
Check out the kristal codec as suggested in the "How To..convert" troubleshooting part (at the end..)
It helped me to open files which wouldn't open earlier -
try installing an older codec divx alpha3.11 or may the dodgy angelpotion,or smr....
Conversion of TIVO into MPG
By edsmith77 in forum DVB / IPTVReplies: 9Last Post: 8th May 2011, 10:50 -
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 03:22 -
mpg to avi conversion
By rwagar in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 23:27 -
MPG to DVD conversion
By Exc414 in forum Video ConversionReplies: 3Last Post: 8th Sep 2007, 18:24
