Just looking for some advice on how to author a dvd with menus using vob files. The source disc I got the vob files from never had any menus, but I would like to create my own and then re-burn. I realize I will probably have to demux the files into an audio and video file, but is there a simple authoring tool that I can then use to create menus and drop in the demuxed files?
Thanks in advance.
Try DVD Maestro - their is a really good guide @ Doom9.org
Not sure if you can add VOBs directly - worth a try though.
Dob -
.VOB may not be used directly..
DEMUX and add to authoing "ASSETS"
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 05:39 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 01:11 -
Replacing VOB files : Need urgent help with chapter menus !
By Ash512 in forum MacReplies: 1Last Post: 12th Mar 2009, 04:26 -
creating .ifo from .vob files and keeping menus
By vishalpatel1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2007, 07:40
