  1. When i tried to using IC to convert from VIDEO_TS folder on the disk image to disk image I have the error shows as follows:
    "Failed to set data for K:\Eagles\Eagles\Eagles_IC_7.0.pdi". Can any body show me how to correct the problem. Thank you.
    Regards,
    Hung
  2. i just start a new topic that IC7 has a new update so you may want to check it out, it may help you to fix the problem.
    =-VNPN=-
  3. Originally Posted by hunghuynh
    Regards,
    Hung
    run regedit
    go to HKEY_LOCAL_MACHINE/software/vob
    click on edit/permissions and select allow Full Control
    that should fix this error
