Im trying to convert a DIVX video file which is 82 min long, but when converting to VCD in TMPGEnc, it thinks its about 4 hours long, and i have to wait about 9 hours before it finishes, then i have to trim off the video at the end of the movie, which is just black with no sound.
What seems to be the problem?
If TMPGEnc says that the video time / runtime is way too long
Try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and reopen the video. If that doesn't help you can always use the source range to select exact what to encode, under Settings->Advanced in tmpgenc.
www.dvdrhelp.com/tmpgenc#problems -
Or when that happens I just hit the stop button in TMPgenc when it goes to blank, The converted file is fine, no trimming needed.Originally Posted by HamishT
Good Luck
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
audio way longer than video
By sn0wd0g in forum DVD RippingReplies: 5Last Post: 14th Jul 2008, 00:58 -
trying to capture atari video that my canon thinks is junk...
By zimcricket in forum Capturing and VCRReplies: 10Last Post: 17th Jun 2008, 20:59 -
Premiere Elements thinks the project is longer than it really is
By cdig04 in forum EditingReplies: 4Last Post: 22nd Apr 2008, 08:34 -
How do I upload a video to youtube that's longer than 10 min? (besides.....
By Spritemoney in forum Video ConversionReplies: 3Last Post: 27th Dec 2007, 11:54
