I have no problem with the capture of video, editing, or conversion from AVI to Mpeg to VCD, but the Quality could be better. When I play the VCD on the TV, it looks somewhat boxy, especially when there is movement.
Any ideas why?
Any ideas why?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Do you mean blocky? If you turn up the Video Data rate or the performance this will lessen and sometimes eliminate the blockiness. Of course, it also depends on what standalone DVD player you to as to how the video looks. -
If you are using TMPEnc, then there is a soften block noise option on the quantive matrix tab. Also, try using the calculator and two pass VBR. It works great
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
NEWBIE - Converted and burned XVID to DVD -- Blurry/boxy on TV
By baldieme in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 18:47 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 22:18 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 18:36
