I want to make a Mpeg 1 compliant video that will load into Movie Factory without the need for re-encoding
Roy
I would like it so that Movie factory will except as an Mpeg 1 and just convert the audio to 48khz and then write it to a DVD, I have tried VCD and MF goes thro the full conversion
Roy -
Did you select same system as the source in MF? NTSC(29,976 fps) or PAL(25.fps), if you change from NTSC to PAL or vice versa will MF reeencode.
Is the mpeg1 resolution within the dvd standard? 352x240 or 352x288
If it is NTSC film(23,976 fps) then will mf reencode cause it is not a valid mpeg1 dvd.
Use MF to check the source info when adding the mpeg. -
This is video data, I have MF set for PAL and it still recodes
Video Type MPEG 1
Total Frames 81,591
Attributes 24bits 352 x 288
Frame rate 25.000
data rate 1150
Roy -
Then it should work. Are you using the latest moviefactory 2?
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 16:35
