I just downloaded a movie and if i right click on it and check properties, it only says the video codec (XViD) but no audio codec. I want to convert the movie to burn it on dvd, but TMPGEnc wont reconize the aduio. Ive tried to Virtual Dub the audio but it wont convert it. anyone else have a video it this weirdness? any ideas?
It proberly AC3 audio get the ac3 mod version of virtual dub and you will be able to extract it
Or you can use graphedit or nandub
heres the thing tho, i can pull it out as a wav, but i get those chop noises. Can i extract it out as mp3 or AC3 and then convert it to mp3?
Your picture above never came up before, Its not AC3 then.
No, as far as i know you have to extract it as wav then convert it afterwards to mp3 or mp2 for multiplexing with mpv or mp2 after converting
As it is now its proberly VBR encoded audio try using Tmpgenc to convert it to an mp2 and see what happens , See if the choppyness is still there -
GOt it. I used the Demux Audio function and got an AC3 file. Then I used Besweet to convert it to a WAV to use in TMPGEnc.
Video duration discrepancy in 'properties'.
By LT2012 in forum Video ConversionReplies: 6Last Post: 20th Apr 2012, 21:06 -
Sort files by certain video/audio properties
By darknite999 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2011, 15:40 -
Video Properties
By shockgolf in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2011, 00:59 -
Tool to show properties of DVD-Video
By ptrk.mj in forum DVD RippingReplies: 18Last Post: 18th Dec 2010, 02:03 -
AVI video properties missing
By Ayeohn in forum DVD RippingReplies: 3Last Post: 19th Dec 2009, 04:58
