How could I get subtitles with MainConcept?
To get to the mainconcept forums, go to www.mainconcept.com and then to support and select to go to the new forums. From there, select the codecs forum.
Now, to your question of getting subtitles with mainconcept, I am afraid the question is irrelevant. It is not an encoder's task to process or add subtitles to a movie. You either do that before encoding (hard coding subtitles with, for example, VirtualDUB) or if you do a DVD add them within the authoring program (if you use one that supports subtitles).The more I learn, the more I come to realize how little it is I know.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 14:34 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 23:31 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
