I have been trying some analog captures using my Sony DV camcorder as a pass-though with the firewire connection to my computer. Whenever I capture DV type 2 the resulting avi gradually looses audio sync such that it is about 1-2 secs off after an hour. However, when I capture in type 1 mode the audio stays in sync the whole time. This happens whether I use DVIO or Scenalyzer to capture and in all cases I did not have any dropped frames. Does anyone have any idea why this would happen?
I currently have the panasonic codec installed for type 2 files, but I'm not sure if this influences the capture or not. Is a particular DV codec used during capture, or is the raw data from the camcorder just formatted and saved to disk by the capture program without any usage of the codec?
A related question, does anyone know if the MS DV codec still has the upsampling chroma bug with DirectX8.1? The avisynth documentation refers to it but not to a particular version.
"FixBrokenChromaUpsampling(clip)
I noticed that the MS DV codec upsamples the chroma channels incorrectly, and I added a FixBrokenChromaUpsampling filter to compensate for it. You should put this after DirectShowSource if you're using the MS DV codec, or if you notice off-color lines appearing in interlaced images"
I don't know why this happens but a workaround would be to capture in type 1 and convert to type 2 using the Ulead converter in the tools section. I am not 100% sure but I don't think that a codec gets used upon capturing a type 2 DV file. It only gets used upon editing a type 2 file. A type 2 DV avi file essentially extracts the audio from the DV file and keeps it as a separate audio stream. Because of this, there is more risk of a type 2 file being out of sync than a type 1 DV avi file. However, I have not experienced this out of sync probem with type 2 DV avi files.
I have similar issues regarding sync but my experience has been that if I use a wdm based capture program such as IuVCR or Ulead Video Studio 7 even with a type 2 codec my a/v sync issues disappear. I believe dvio is vfw based ( it worked under Win98 even before the Digital Video patch).
I too tried passthru but I had better luck copying from my VCR deck to my DV camcorder then transferring from camcorder to computer via firewire. The DV time base coding was more stable.
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 18:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 13:52
