Results 1 to 11 of 11
  1. Member wwaag's Avatar
    Jan 2002
    Olympic Peninsula, US
    I've acquired both the MainConcept and new CCE Basic encoders. Just finished some speed trials and thought I would post the results. For all trials, I used the same video clip--a 2 min DV file I captured from an ADVC-100 using Scenalyzer and saving in a Type 2 format. I used 2 methods--a direct file encode and frameserve using Vdub. The clip was 121 sec in duration. For CBR encodes, I used 6000Kbs. For VBR encodes, I used a mean of 6000 with 2000 min and 8000 max. All audio was encoded at MP2, 224kbs. Here are the results
    Direct Encode
    MainConcept
    1-pass-VBR--117 sec--speed 1.03
    1-pass-CBR--112 sec--speed 1.08
    CCE
    1-pass-CBR--90 sec--speed 1.34
    2-pass-VBR--174 sec--speed .70
    Frameserve through Vdub
    MainConcept
    1-pass-VBR--156 sec--speed .78
    1-pass-CBR--153 sec--speed .79
    CCE
    1-pass-CBR--117 sec--speed 1.03
    2-pass-VBR--225 sec--speed .54
    The only direct comparison is really the 1-pass CBR since MainConcept does not offer 2 pass-VBR and CCE does not offer 1-pass VBR. For CBR 1-pass, CCE took 90 sec vs 112 sec for MainConcept. Overall, I would say that CCE is definitely faster. Any of the speeds greater than 1 indicates better than real-time encoding--bottom line--both are very fast.
    Since quality is such a subjective matter, I haven't done any detailed comparisons of the resulting encodes under these various conditions. There are just too many variables. However, I do offer a couple of personal observations. I finished an encode of Star Wars (from laserdisc) using Tempgen. With filtering and only CBR, it took 12 hours--looked very good to me--almost indistinguishable from the laserdisc. Using CCE 2-pass only for a selected segment (without filtering), the resulting encode was almost indistinguishable from the Tempgen encode--basically same quality--lot less time.
    For a video clip from a Hi8 source, I compared MainConcept (1 pass VBR)and CCE (2-pass VBR). Both looked very good. However, CCE was a lot better on certain scenes which included shots of carpeting. In MainConcept, the carpet appeared to "move", whereas the CCE encode was very smooth and detailed with no apparent movement. So for home video work, my choice is clearly CCE.
    Hope these observations are of some use.
  2. I have also run tests comparing CCE Basic mpeg 2 2 pass vbr with MainConcept 1 pass VBR. The test clips were designed to stress the encoder. In all cases the Q (quantanization) levels, as measured with Bitrate, of CCE were consistantly lower than Mainconcept under the same conditions. Usually the lower Q levels indicate a better encoder but that does not always appear the same visually. Visually CCE produced a slightly better looking video than Mainconcept. As with all these type of tests the results are subjective.
    - LC
  3. Thanks for the information. I think TMPGEnc better get moving with their speed issue or they will start to lose market share.
  4. Member wwaag's Avatar
    Jan 2002
    Originally Posted by Lamont Cranston
    I have also run tests comparing CCE Basic mpeg 2 2 pass vbr with MainConcept 1 pass VBR. - LC
    Since you've used MainConcept quite a bit from reading your posts, are there any settings that you would recommend for 1 pass VBR? Unlike CCE, there are tons of options. I've only played around with a few (like line noise filtering, and setting the intrablock DC precision to 10 bits). I've found that none of these changes dramatically alter encode time--or picture quality to my old eyes. Most of my encoding using MainConcept is for satellite captures, which is usually pretty good video from the start, so I usually resort to using the "standard" settings, except for the average bit rate to control the size of the resulting file. There are published "templates" for Tempgen, but none for MainConcept as far as I know. Any suggestions or recommendation you might have based on your experiences would be greatly appreciated. Thanks.
  5. According to some other post, MainConcept employees said the Encoder is a very new program. It has just started catching on in the past couple of months.
    Sep 2001
    Florida
    wwaag:
    I too have looked for this info. All I could find was at: http://www.mainconcept.com/forum/viewtopic.php?t=54 scroll down to bottom of page
    There are some 'optimized' profiles that come with Vegas Video and the Adobe Premiere 6.5 versions of the encoder but I didn't find a 'magic bullet' in reviewing the text of those.
    If you find any other info please share.
  7. Member SaSi's Avatar
    Jan 2003
    Hellas
    Here are the settings I use with MCE for 1 pass VBR. (I reached these settings after prolonged testing between Tmpgenc (my previous encoder), MCE and trial CCE BE).
    Detailed Settings:
    (FOR PAL Interlaced Video)
    Frame size 720 x 576,
    FrameRate 25
    Field Encoding = Bottom Field First
    Deinterlacing = None
    Search Method = 11
    Search Range = 5
    Enable Line Filtering = unchecked
    Advanced Settings
    Video Settings:
    Aspect Ratio = 16:9 for widescreen movies, 4:3 for 4:3 episodes and movies
    GOP Structure:
    I Frames = 15
    P Frames = 5 (This decreases the number of P frames in favour of B frames)
    Closed GOP every = 5 GOPS
    Bitrate Type: Variable Bitrate
    Rate Control Mode = Mode 1
    Maximum = 6000
    Average = 4800 (This makes an up to 2 hours movie <4Gb so that the audio AC3 can also fit. Have used down to 3200 for very long movies with equaly excellent picture).
    Minimum = 200
    Constant Quality = 10
    Advanced Video Settings
    Profile ID = Main Profile
    Noise Sensitivity = 12
    Motion Search Mode = 11
    User Quantization Matrices = Checked
    Do Half Pixel = Checked
    Set Motion Search areas = Enabled and 3 h x 3 v
    In terms of Quant. Matrix, I use the following for
    INTRA BLOCKS NON_INTRA_BLOCKS
    8 16 16 22 26 27 29 34 16 18 20 22 24 26 28 30
    16 16 16 26 27 29 34 37 18 20 22 24 26 28 30 32
    16 16 18 27 29 34 34 38 20 22 24 26 28 30 32 34
    22 26 27 31 36 37 38 40 22 24 26 28 30 32 34 36
    26 27 29 36 39 38 40 48 24 26 28 30 32 34 36 38
    27 29 34 37 38 40 48 58 26 28 30 32 34 36 38 40
    29 34 37 38 40 48 58 69 28 30 32 34 36 38 40 42
    34 37 38 40 48 58 69 79 30 32 34 36 38 40 42 44
    The matrices above are adoptations from the KWAG matrices for Tmpgenc. KWAG also modifies the GOP structure heavily in an undocumented way for Tmpgenc. I find it is not required to do so.
    The above settings produce excelent results and encoding in record speeds. My P4/2.57GHz encodes at x1.7 almost an original mpeg stream. This last thing is what makes MCE excelent for me. I rip the Mpeg video stream out of the VOB file (a 4 minute process), feed it to MCE and after 1.5 hours I have a re-encoded movie with excelent picture quality.
    The more I learn, the more I come to realize how little it is I know.
  8. Member SaSi's Avatar
    Jan 2003
    Hellas
    After viewing the matrix tables, I realized I didn't leave enough space between them. Use the first 8 numbers for the Intra block matrix and the next 8 numbers on each row for the non-intra block matrix. Sorry about the messing up.
  9. Member wwaag's Avatar
    Jan 2002
    SaSi,
    Thanks for your quick response. Could you send me an e-mail with one of your *.ces files as an attachment. This would certainly be the easiest way (at least for me--I'm a lousy typist). Thanks.
  10. I agree MainConcept produces great quality vids using KWAGs matrix from www.kvcd.net. The reason for using that matrix is that it helps compress the mpeg file more without losing quality.
  11. Member SaSi's Avatar
    Jan 2003
    Hellas
    wwaag,
    for the benefit of the thread, I copy the profile (Mainconcept profile) in this posting.
    MCE stores it's templates at
    C:\Documents And Settings\{Login Name}\Application Data\MCMPEGEnc
    using files with an extension of ".mef"
    Cut the part of the posting below the ----- and paste it into notepad saving the file as DVD_TWEAK.mef
    Then start MCE and use this profile.
    [MAIN]
    StreamType=1
    MpegType=4
    VideoMode=1
    AudioMode=2
    Width=720
    Height=576
    SampleRate=48000
    LineFiltering=1
    Deinterlacing=0
    ID=mep-profile
    Name=DVD KWAG
    [basic]
    settingsVersion=2
    online=0
    perfLevel=16
    motionSearchType=23
    mpegType=4
    deinterlacing_mode=0
    relaxed_standards=0
    [video]
    videoPulldownFlag=0
    rateControlMode=1
    aspectRatio=3
    frameRateCode=3
    iFramesInGOP=15
    ipFrameDistance=5
    bitrateFlag=0
    mquantValue=10
    constBitrate=6000000
    maxBitrate=6000000
    avgBitrate=4800000
    minBitrate=200000
    timeCode0=0
    dropFrameTC=0
    constrParms=0
    closedGOPs=0
    [audio]
    audioLayer=2
    audioMode=2
    deEmphasis=0
    audioBitrate=11
    privateBit=0
    copyrightBit=0
    originalBit=0
    errorProtection=1
    psychModel=2
    [multiplex]
    programStreamType=4
    vbrMultiplex=1
    padVCDAudio=0
    writeProgramEndCode=1
    muxSVCDScanOffsets=0
    alignSequenceHeaders=1
    usePrivateStream2=1
    useComputedBitrate=0
    frameTimestamps=2
    muxPulldownFlag=3
    userMuxRate=25200
    sectorSize=2048
    packetsPerPack=1
    videoBufferSize=232
    audioBufferSize=4
    audio1BufferSize=4
    sectorDelay=0
    videoDelay=180
    audioDelay=180
    audio1Delay=180
    alwaysWriteSysHeader=0
    maxFileSize=0
    muxStartTime=0
    muxStopTime=0
    resetClocks=0
    setBrokenLink=0
    writeEndCodes=0
    [advVideo]
    profile=4
    level=8
    chromaFormat=1
    colorPrimaries=5
    transferCharacteristics=5
    matrixCoefficients=5
    videoFormat=1
    intraDCPrec=1
    vbvBufferSize=112
    forceVBVDelay=1
    displayHorizontalSize=720
    displayVerticalSize=576
    progressiveSequence=0
    progressiveFrame=0
    fieldPictures=0
    topFieldFirst=0
    repeatFirstField=0
    intraVLCFormatI=1
    intraVLCFormatP=1
    intraVLCFormatB=1
    framePredDCTI=1
    framePredDCTP=1
    framePredDCTB=1
    quantizationScaleI=1
    quantizationScaleP=1
    quantizationScaleB=1
    alternateScanI=1
    alternateScanP=1
    alternateScanB=1
    writeSequenceDisplayExt=0
    writeSequenceEveryGOP=1
    writeSequenceEndCode=1
    embedSVCDUserBlocks=0
    writePictureDisplayExt=0
    frameCentreHorizontalOffset=0
    frameCentreVerticalOffset=0
    qtNoiseSensitivity=12
    featureFlags=0
    reactionParameter=0
    initialAverageActivity=0
    initialIComplexity=0
    initialPComplexity=0
    initialBComplexity=0
    initialIFullness=0
    initialPFullness=0
    initialBFullness=0
    minFramePercentage=25
    padFramePercentage=0
    autoVectorLengths=1
    horzPelMovement=3
    vertPelMovement=3
    forwHorzFCodeP=2
    forwVertFCodeP=2
    forwHorzSearchP=15
    forwVertSearchP=15
    forwHorzFCodeB1=1
    forwVertFCodeB1=1
    forwHorzSearchB1=3
    forwVertSearchB1=3
    backHorzFCodeB1=2
    backVertFCodeB1=2
    backHorzSearchB1=12
    backVertSearchB1=12
    forwHorzFCodeB2=1
    forwVertFCodeB2=1
    forwHorzSearchB2=6
    forwVertSearchB2=6
    backHorzFCodeB2=2
    backVertFCodeB2=2
    backHorzSearchB2=9
    backVertSearchB2=9
    forwHorzFCodeB3=2
    forwVertFCodeB3=2
    forwHorzSearchB3=9
    forwVertSearchB3=9
    backHorzFCodeB3=1
    backVertFCodeB3=1
    backHorzSearchB3=6
    backVertSearchB3=6
    forwHorzFCodeB4=2
    forwVertFCodeB4=2
    forwHorzSearchB4=12
    forwVertSearchB4=12
    backHorzFCodeB4=1
    backVertFCodeB4=1
    backHorzSearchB4=3
    backVertSearchB4=3
    forwHorzFCodeB5=0
    forwVertFCodeB5=0
    forwHorzSearchB5=0
    forwVertSearchB5=0
    backHorzFCodeB5=0
    backVertFCodeB5=0
    backHorzSearchB5=0
    backVertSearchB5=0
    forwHorzFCodeB6=0
    forwVertFCodeB6=0
    forwHorzSearchB6=0
    forwVertSearchB6=0
    backHorzFCodeB6=0
    backVertFCodeB6=0
    backHorzSearchB6=0
    backVertSearchB6=0
    forwHorzFCodeB7=0
    forwVertFCodeB7=0
    forwHorzSearchB7=0
    forwVertSearchB7=0
    backHorzFCodeB7=0
    backVertFCodeB7=0
    backHorzSearchB7=0
    backVertSearchB7=0
    ignore_frame_interval=0
    user_iquant=1
    intra_q[0]=8
    intra_q[1]=16
    intra_q[2]=16
    intra_q[3]=22
    intra_q[4]=26
    intra_q[5]=27
    intra_q[6]=29
    intra_q[7]=34
    intra_q[8]=17
    intra_q[9]=16
    intra_q[10]=16
    intra_q[11]=26
    intra_q[12]=27
    intra_q[13]=29
    intra_q[14]=34
    intra_q[15]=37
    intra_q[16]=16
    intra_q[17]=16
    intra_q[18]=18
    intra_q[19]=27
    intra_q[20]=29
    intra_q[21]=34
    intra_q[22]=34
    intra_q[23]=38
    intra_q[24]=22
    intra_q[25]=26
    intra_q[26]=27
    intra_q[27]=31
    intra_q[28]=36
    intra_q[29]=37
    intra_q[30]=38
    intra_q[31]=40
    intra_q[32]=26
    intra_q[33]=27
    intra_q[34]=29
    intra_q[35]=36
    intra_q[36]=39
    intra_q[37]=38
    intra_q[38]=40
    intra_q[39]=48
    intra_q[40]=27
    intra_q[41]=29
    intra_q[42]=34
    intra_q[43]=37
    intra_q[44]=38
    intra_q[45]=40
    intra_q[46]=48
    intra_q[47]=58
    intra_q[48]=29
    intra_q[49]=34
    intra_q[50]=37
    intra_q[51]=38
    intra_q[52]=40
    intra_q[53]=48
    intra_q[54]=58
    intra_q[55]=69
    intra_q[56]=34
    intra_q[57]=37
    intra_q[58]=38
    intra_q[59]=40
    intra_q[60]=48
    intra_q[61]=58
    intra_q[62]=69
    intra_q[63]=79
    user_niquant=1
    inter_q[0]=16
    inter_q[1]=18
    inter_q[2]=20
    inter_q[3]=22
    inter_q[4]=24
    inter_q[5]=26
    inter_q[6]=28
    inter_q[7]=30
    inter_q[8]=18
    inter_q[9]=20
    inter_q[10]=22
    inter_q[11]=24
    inter_q[12]=26
    inter_q[13]=28
    inter_q[14]=30
    inter_q[15]=32
    inter_q[16]=20
    inter_q[17]=22
    inter_q[18]=24
    inter_q[19]=26
    inter_q[20]=28
    inter_q[21]=30
    inter_q[22]=32
    inter_q[23]=34
    inter_q[24]=22
    inter_q[25]=24
    inter_q[26]=26
    inter_q[27]=28
    inter_q[28]=30
    inter_q[29]=32
    inter_q[30]=34
    inter_q[31]=36
    inter_q[32]=24
    inter_q[33]=26
    inter_q[34]=28
    inter_q[35]=30
    inter_q[36]=32
    inter_q[37]=34
    inter_q[38]=36
    inter_q[39]=38
    inter_q[40]=26
    inter_q[41]=28
    inter_q[42]=30
    inter_q[43]=32
    inter_q[44]=34
    inter_q[45]=36
    inter_q[46]=38
    inter_q[47]=40
    inter_q[48]=28
    inter_q[49]=30
    inter_q[50]=32
    inter_q[51]=34
    inter_q[52]=36
    inter_q[53]=38
    inter_q[54]=40
    inter_q[55]=42
    inter_q[56]=30
    inter_q[57]=32
    inter_q[58]=34
    inter_q[59]=36
    inter_q[60]=38
    inter_q[61]=40
    inter_q[62]=42
    inter_q[63]=44
