I followed the instructions on the site to rip a DVD-9 to one recordable DVD+R using DVDdecrypter & instant copy(trial version). All went well until the end, with instant copy, it had an error message saying that "4.5 GB free disk space are required but only 1.16 GB are available". I don't know why I got this message unless it has something to do with it being a trial version. Please tell me what to do next to get this copied.
http://www.buy.com/retail/product.asp?sku=20353177&loc=105
and your HardDrive format must be NTFS.=-VNPN=- -
Ok,
My hard drive is formatted in NTFS. Where I think the problem lies is that my hard drive is partitioned. C: portion and logical portion F: When I check the F: portion in explorer, amazingly it has 1.16 GB of free space. So, in Instant Copy, I find the source in C: , I state the destination DVD+RW(Memorex) push the button to start and thats when the error message about not having enough space comes up. Does this mean I have to resize/repartition my hard drive? Or is there another setting I can change. P.S. My 30 day trial is uo today. -
hi hevsdr,
if you don't want to re-partition your drive ... you can buy a second HD and put it on an external case like i did. I put a 20G HD on a external firewire case and it works great, or you can put it on a USB external case as well.
Hope that helps
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12
