when i use virtualdub and scan for video stream errors and find them how do i then fix them?
First set in video and audio tab to "direct stream copy" and then scan video for error which will look like this if it has any:
Then save it as a new AVI
But if you get this warning in Virtual Dub:
You need to change the audio to "full processing mode" and then do the scanning and save as a new AVI. -
so after it detects bad frames then go to file-save as avi and that will fix it?
when i do get video dtream errors would that cause audio sync errors when i split the file? how do i fix this?
Originally Posted by rotorspeed
then save it as a new AVI and you will have a good version and then if you wanna cut it later,do as normal.
VirtualDub File [path] does not have a video stream error
By fershad in forum Video ConversionReplies: 4Last Post: 25th Jan 2012, 06:11 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Virtualdub direct stream copy takes _forever_. What's going on?
By Colmino in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2008, 08:01 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
