I have been having a problem capturing with vdub. I'm getting a lot of dropped frames, and I really shouldn't be. I have two systems, one thats a PIII 600 running windows 2000, and that captures fine, but the other one is an AMD 1.2mhz Thunderbird, with an ATA100. When I try to capture with the 1.2 mhz computer, with the same Vdub settings, I get tons of dropped frames. The 1.2 is running windows ME. I notice that it's not taking a lot of cpu cycles to capture, around 20% or so, but it's dropping frames like crazy. I'm capturing from a satellite feed. One thing I noticed, eventhough I have the frame rate set at 29.97, it's going up to like 33 to 34 frames per second at times. Someone please advice.
Thanks.
Oh, one more thing, I'm using the PicVideo codec for capturing, setting at 18.
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 10:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 12:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
