using Leadtek my ViVo card, or any card and to have good video/audio sync, up to 1:30min on 700mb CD and with good quality.
Does anyone know to do this and which codec, I can capture up to 1 hour on 700MB but I get always out of synch. Audio compresion=Microsoft ADPCM
Generally speaking you don't capture in the final codec. You capture in MJPEG or Huffyuv and PCM audio. Then you edit, filter, and encode (with multi-pass usually). Capturing directly to DivX truly sucks, you only get single pass, and generally speaking the lack of filtering looks bad and forces your bitrate way up from 'sparkles' and noise.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ok, so answer was" DOnt capture directly to divx.
My question: If i capture to MJPEG-what program to use to convert that in DIVX-without losing audio/video synhonization
AND another question: I usualy always have white solid square across captured video for a 10 sec. What is the problem
Thank you
X264 / XVID realtime encoding with OTA Capture
By Frank420 in forum Capturing and VCRReplies: 4Last Post: 15th Mar 2012, 15:03 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best tool for realtime DV preview/capture?
By Drevin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Feb 2011, 10:28 -
FLV files as a capture format......from a DVCAM in realtime?
By Palmer Eldritch in forum Capturing and VCRReplies: 2Last Post: 10th Dec 2009, 22:41 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 15:11
