Can i batch encode with CCE ?
If so do i just add say 2 files into the big white box one after the other and then set the templates ?
Thanks BM
Yes that's exactly how you do it. Once the first project finishes it automatically starts encoding the second one.
How would CCE know that you wanted to join the 2 files together BJ_M, how do you tell it to do that ?
enter your first source file into main window ..
double click it to go to settings as you normaly would .
next to input source file in upper left - there is a button marked setting (something like that ) .. click it and you see what appears to be your main window again .. but if you add files to this window ... they will be added to the final output .. -
the new CCE 2.67 fixes the template bug .. when you make your own templates and have it checked , then add files .. the resulting encode will not be based on your template (version 2.64 - 2.66) , there was as simple workaround where you would select another template first , then reselect the one you want each time before you add files . 2.67 seems to have fixed this .
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 15:57 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
Feature REQ:True batch encode
By tszpara in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jan 2010, 04:30 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 12:32 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52
