I used to convert my SVCD to VCD (to save disc) by using Tmpge Ver 2.5.9.
It working out well at the first few times, then it started to crash...everything just freez; need the hard reboot. Then I try Off the Preview during the conversion process, well it work. It just work.
Well, don't frame me if it doesn't work on your case or this had been post before. Just wanna give a helping hand only.
My pc spec is Athlon 1.333, SDRAM 256, MSI KT133, ATA 40GB 7200, DirectX 9.
Results 1 to 1 of 1
Get your original and low price VCD from http://www.ordervcd.com/l
iMovie - Importing time : Does a hint exist?
By iwiiiiiiiiii in forum MacReplies: 4Last Post: 21st Sep 2011, 17:31 -
Working with VOB2MPG: speed issue hint
By cdgmol in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 31st Jul 2009, 17:57 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
Hint for deciding on a camcorder
By renshaw8 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 1st Jun 2009, 14:24 -
Creating video files larger than 1 GB with mencoder, important hint
By penguin74 in forum LinuxReplies: 1Last Post: 4th Nov 2007, 20:13
