Good morning, I am trying to import the chapter list I made with chapter x tractor into vcd easy but when I right click to paste the file nothing happens. I am following Sefy's Guide. Am I missing a step or a file to add into the chapter xtractor or vcdeasy folder? TIA for any help.
Results 1 to 17 of 17
stinky tuna
Iwill MPX2
2 x xp2100 @ 158 fsb
2x Crucial 256 PC2100
Antec 550 EPS12V
100g WD 8mb cache
Liteon DVDrom and CDburner
Win XP pro -
I had the same problem!
Overcame it by changing the format in Chapterxtracto to the same format that VCD easy uses. Then it was a case of cutting & pasting this info as you would using any text based program.
Have a nice day
Thanks Joker2, I got help from 2cpu, I missed the copy step.
Now to get rid of the error messages in vcdeasy when I try to burn. It shows I don't have drivers for my cdburner. WTH is up with that.
stinkystinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
VCDeasy's burning software does'nt cover all burners. I just seleceted a burner that seemed to be close to my own (although not exactly). This seemed to work and am able to burn by VCDs this way.
If you are using XP you may find that a visit to any numbe of websites will give you the driver you may need. (Easy cd creators site for instance) -
8) Thanks Joker2. Will try your suggestions.
stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
You must have ASPI v4.60 Build 1021 installed! and also I suggest you pick
the generic-mmc driver, it works for just about all burners i've tested with.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi Sefy, you are correct. I have v4.6 on my rig. which aspi should I install? can I also ask for some help on how to upgrade to the aspi you suggest.
I'll also try the generic-mmc driver. Thanks again.
stinkystinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
You need to have 4.6 Build 1021, check the main page of my guide and you
can download it from there. and let me know how it goes.Email me for faster replies!
Best Regards,
Sefy Levy,
Thanks for the quick reply Sefy. Checking it out now. 8)
stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
Waiting to hear if everything is working!
Best Regards,
Sefy Levy,
sorry sefy, didn't have time to mess around last night. Was watching my Lakers get their butts whoooped by the Queens. Dang, after that wasn't in the mood to do much of anything. Will do it tonight and post asap. Sorry bout that, and thanks again for the help.
stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
No Problem! just hoping to hear some good news 8)
Best Regards,
Sefy Levy,
Ok, I'm pretty sure that will fix it. Hehehe. Thanks again.
stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
Hi Sefy, I have updated to version 4.6 1021. Now when I run Aspi checker, it is now back to red. winaspi.dll and wowpost.exe is N/A????
what did I do wrong??? Please help.stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
Try using forceaspi. It worked for me when I had problems with dvd2svcd. Although, make sure you read the index.htm included with it and back up your current aspi layer with the tools included with forceaspi in case it doesn't work.
forceaspi for win 9x, me, and 2k http://www.dvd2svcd.org/forceaspi17.zip
forceaspi for xp http://www.dvd2svcd.org/xp-aspi.zip -
Thanks Donny, will try that then.
edit. thanks a lot that did it, I am now at 4.60 (1021) thanks for the help everyone.stinky tuna
Iwill MPX2
Antec 550 EPS12V
100g WD 8mb cache
Win XP pro -
I suggest you also check the main pages of my guides, they include a link for
installing v4.60 Build 1021 correctly without the use of ForceASPIEmail me for faster replies!
Best Regards,
Sefy Levy,
Importing from APP to AE, why is it all black?
By Devilsadvocate in forum EditingReplies: 5Last Post: 27th Mar 2012, 19:19 -
Importing Chapters into TMPGEnc from XML files
By TheLaserdisc in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2012, 16:05 -
importing .dv in iMovie
By sneike in forum MacReplies: 1Last Post: 27th Oct 2008, 07:11 -
DVCPro 25/50 importing to Premiere?
By LuckieGW in forum EditingReplies: 3Last Post: 1st Mar 2008, 19:59 -
Re:Importing from camcorder
By gepuk2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Nov 2007, 18:15
