Hi again.
This is a continuation of my last post (https://www.videohelp.com/forum/viewtopic.php?t=148052) but can be treated separately.
I have had MPEG Info analyse 12 video files, 3 of which work on my new DVD player using the DVD-SVCD "standard", the other 9 don't. I have taken PAL/NTSC, 4:3/16:9, resolution and bitrate into account – the *only* common denominator that separates the 3 that work flawlessly from the 9 that don't (they "stutter" as if the player is skipping 1 frame every half second) is that the 3 that work all have a bitrate of 2.52 or more whereas the 9 that "skip" have a bitrate of 2.50 or below (there figures relate to the video track only, not the finished multiplexed MPEG2). I think it sounds unlikely that there should be a cut-off point for MPEG2 bitrate (particularly as "high" as this) not to mention how odd it is that 1.70 bitrate skips just as much (no worse) than a 2.50, but perhaps that's because I don't know any better
Do you?
Side question: is there any way of increasing the (apparent) bitrate of a videofile apart from re-encoding it? Sorry to keep pestering about this, but I really do like the DVD-SVCD format, and it's a pity that the Pioneer DV-350 (which is an excellent machine in every other way) seem ot have such high demands. Particularly since the very same video files play flawlessly when burned as a standard SVCD.
Please respond - I need your help.
Thanks.
/Wizeman
Results 1 to 1 of 1
"I have not failed. I have only learned what does not work."
-Edison
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 01:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03
