Just downloaded not another teen movie ,and after i have saved it and then opened file in V.DUB i get a message saying "virtual dub has detected an improper V.B.R audio encoding in the source avi file and will rewrite the audio header with standard C.B.R. values during processing for better compatability.This may introduce up to 18407m.s. of skew from the video stream. If this is un acceptable decompress the entire audio stream to an un compressed wav file and recompress with a constant bitrate encoder (bitrate 128.3 +/- 16.7 kbps)
could any body shed any light on this as i am completely baffled![]()
Try the virtualdub mp3 freeze version
It's a modified version of Virtualdub that is compatible with VBR mp3 audio.
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
joining problem with v-dub mod
By agent222 in forum Authoring (DVD)Replies: 4Last Post: 2nd Mar 2009, 08:18 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49
