hello i'm having a problem trying to cut or demuliplex any mgeg 1 file that i put in my computer. tmpg will not let me cut or demuliplex, the right size of the file. say i got a 1gig file but when i try to cut or demuliplex it it won't finish to the right size, it comes out to 830mbs or less. it stops short of the end of file. i have tmpg 2.56 but also have 7 different versions. of which i have tryed 4 but the same thing happens when i try to edit will not edit full file. always stops short. any ideas?
Go to tools section and search for a mpeg checker (I can't remember the name "Mpeg Corrector ??)
TMPGEnc works fine with mpegs made with TMPGEnc. If the mpeg is encoded with some other app - all kinds of problems!
/Mats
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 05:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 18:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 11:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 06:59
