If I have a VIDEO_TS folder on my hard drive how do I open that and burn to DVD_R. Instant Copy doesn't seem to want to accept the VIDEO_TS folder so do I just type that name into the "file name" box or is the program looking to see an IFO file or what? Or do I just go to the VIDEO_TS folder and type in any name I want for the file name?
U will have 2 burn it with either nero, vob instant cd or prassi instant cd will not burn unless in an image file
Well it's an image file that I'm trying to make. My question is really how do I open or select a ripped VIDEO_TS file/folder with Instant Copy to make a hard drive image file?
I got the program to open a VIDEO_TS folder but how do I remove a Title set? The check boxes next to all the Title sets are grayed out.
if its what I think U want look at the guides for ifoedit!! if U want to adjust the titleset by removing menu options there is a program called menuedit. I'm not really sure what U want to do as its not explained 100% & if U want make an image again U need a program called imagetool which U can either get from here in the tools section or dooms site.
kev -
I want to remove some of the title sets or DVD extras but keep the menu so the quaility of the movie is improved if that makes any sense.Originally Posted by P@iNKilleR
if U can find any info or the reg hack for instantcopy & select customize in the details U can deselect what U want.. now this is the easy bit afterwards unpack your image with pdixtract & run menu edit & u can bar the menu from entering the subs & extra's menu keeping what U want in the main body of the film.
Kev! -
See these useful links.
1) All the answers here
http://forum.doom9.org/forumdisplay.php?s=&forumid=65
2) link to reg hack here
http://www.dvd9to5.com/IC7.01reghacks.zip
You can also link reg hack from here
http://www.dvd9to5.com/Instant%20Copy.htm
3) Image mount tool
http://www.daemon-tools.org/
4) PDI tools
http://forum.doom9.org/showthread.php?s=&threadid=47259
5)IC helper Programs
http://forum.doom9.org/showthread.php?s=&threadid=46213
6) And last but not least mine should have all the links on one of the IC pages.
Should be able to find what you need here and PS I think IC7 has an update out.(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 15:12
