Like the subject says, how to link menu images to my chapters?
I'm using VCDEasy 1.1.4
After you have added in the Main tab your menu images and movie-mpegs you have to create in the Chapters tab the chapters of your movie-mpegs. Afterwards you select in the Interactivity tab your menu image and add in the numeric keys field the references to the chapters you created before. Then you can select the chapter by the corresponding number if you see the menu image on the TV screen.
Jürgen
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Creating Animated Menu images
By DesertAvenger in forum Authoring (DVD)Replies: 4Last Post: 15th Sep 2009, 23:30 -
Inactive menu link
By benbar in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2008, 18:01 -
putting a link to website on vcd menu. Is it possible.
By Mark-It in forum VCDEasy GeneralReplies: 1Last Post: 21st Dec 2007, 23:08 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 12:22
