Hi,
I got my new DRU500AX drive. I just installed small DLA software that you can use to drag'n'drop files into DVD-+RW media.
What is different between DLA drag'n'drop and real burning?
How come real burning takes much longer whereas DLA drag'n'drop takes 5 seconds?
DLA is suitable for RW-type media (especially +RW with lossless linking). It allows you to use the disk like a floppy with about a 3.0 MB/sec I/O speed, which isn't shabby.
The downside is that many DVD-ROM machines can't read the media unless you "Make Compatible" the media.
For real burning, you have to "erase" the RW media, then burn it inside of a program - not as convenient as DLA.
DLA (although I like Nero InCD better) is much more convenient for imprompty backups, etc......
However, drag'n' drop doesn't take "5 seconds" - the initial format takes a couple minutes or so (although they hide that by doing background formatting on a +RW) and writing time depends on the size of the file -
Thank you for your reply
Last night i formated (quick erased) a DVD+RW cd and then burned some data files on it. And when i try to use it on normal DVD-ROM PC drives they won't read it only Sony DRU500AX does.
What's the point of using +RW media if you can't use on normal computers? -
The point is convenience for backup-type purposes. You need to see if there's a "Make Compatible" buttone somewhere. On "InCD", I believe it's a right-click on the drive. With DLA, I couldn't find one.
In theory, this makes the disk compatible with players that can read a normal DVD+RW (however, be aware that many DVD-ROM drives can't read DVD+RW). -
Actually i couldn't find any "Make compatible" option when i right click on the drive.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
