    Jan 2003
    Taiwan
    I am trying to use the huffy codec to process captures in vdub - but I can't seem to get vdub to recognise my downloaded codecs.
    Where should I be saving the downloads to; and what extensions should the huffy codec have?
    Cheers
    JukeBox
    Rules are made for the obedience of fools, and the guidance of wise men....
  2. Are you sure that you installed the codec?
    Download the Huffy codec. Unzip it to a directory and right click the inf file. Select install. If asked where to find files during the install, point them in to the directory that the files were unzipped into. Once completed, you should not have anymore problems using huffy in VDub. (You can also delete the folder once completed or archive it for future reference).
    BG
    Jan 2003
    Taiwan
    @bgrieb
    Thats the ticket - I had unzipped but not installed! Thanks for the Computing 101 lesson!!!!
    jukebox - suitably humbled.... c/w dunce cap in corner
