after cutting my mpeg movie into 2 halves so i can burn it as a vcd i get an system clock reference not exceptable warning in creat a cd. i can open the halves in wmp and watch them from the hard drive but i cannot burn. how can i fix this
Your Mpeg is not a correct VCD
If you used TMPGEnc the load a VCD template and dont change anything. -
What/how did you cut your MPEG? I would recommend demuxing in TMPGenc, and then cutting with bbMPEG.
Letmeinforgodsake - you can make changes to the standard VCR template and have your VCDs play, IF your stand alone supports xVCD (which most of the newer ones do). -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Nobody said you could not, however he has stated "i get an system clock reference not exceptable warning in creat a cd"
Which is the problem with a non standard VCD.
Why would you want to make a non standard VCD anyway ? unless your trying to save disks, sevral people I know share VCD's non standard works on some, Standard VCD's work on all of them....
The "system clock reference" error is what happens when Easy CD Creator encounters an MPEG with the incorrect pack size. If it didn't complain about anything else, it means that the MPEG itself has all the correct specs (e.g., bitrate, framesize, etc.)
This can occur after cutting with TMPGEnc if you don't put the setting to "MPEG-1 Video-CD".
Thus, when cutting with TMPGEnc, if you MPEG-1 is fully VCD compliant, you MUST change the setting to "MPEG-1 Video-CD". If you leave it on the default "MPEG-1 Auto", then you will get the above problem.
If you are cutting an XVCD, you can use the "MPEG-1 Video-CD (non-standard)" option.
Regards.
Michael Tam
w: Morsels of Evidence -
Thanks, Vitualis, for answering the question very specifically. For me, "MPEG is not a correct VCD" isn't enough to go on. Your mentioning the packet size issue is very helpful. Why "Easy" CD Creator refers to something as nebulous as "system clock reference" makes no sense. It implies something is wrong with your system rather than the file you are trying to add--or something. For creating VCD's/SVCD's, I find NERO to be far superior.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
