How do i get the audio of a .vob to a wav format?
Open the VOB with DVD2AVI (You can find it in the TOOLS section to the left). Look for these under the AUDIO menu:
Set the Audio to 'Track1'
Set Channel Format to 'Auto Select'
Set Dolby Digital to 'Decode'
If your audio is for CD Audio, or for a VCD/CVD/SVCD, select the 48->44.1Khz option. Set it to either 'High', or 'Ultra High' (this affects output quality)
From the file menu, select FILE | SAVE PROJECT. It will generate a WAV file, and a D2V file. You can delete the D2V file.Impossible to see the future is. The Dark Side clouds everything...
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 03:42 -
vob 2 video + audio then increase audio volume then recombine to vob or mpe
By indyram in forum Authoring (DVD)Replies: 6Last Post: 14th Dec 2011, 02:55 -
Replace audio on .vob
By Flugplatz89 in forum Authoring (DVD)Replies: 18Last Post: 25th Sep 2011, 10:16 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3
By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 05:10
