How do you rate it against Ritek? Does it work in 2x? If yes, which kind (blue/gold/unbranded) and where did you get it?
Thanks!
yup, tried one the other day, worked perfect with 1.0g firmware. It was a light purple dye with a white printable surface. Did the nero transfer graph in my liteon dvdrom and it gave out a perfect read. Ive had problems with the ritek discs, i think i just got a bad lot of dvd's.
i used 200 of them before with my panasonic but after a while it start degrading, after i got my sony 500ax it can only burn at 1x so i switch to LEAD DATA, not sure how long the lead data disc can be last but it works fine for me now, burned at 2x and work perfect with my xbox.
i had problem with ritek before with my panasonic...since that i never try ritek again...come to think about it..Lead Data oem for sony..some time you can get disc that say manufacture by sony..sweet -
I have used over 200 blue optodisc on my sony 500a without a single problem. I haven't seen any detiriation of the data. Every one writes at 2X with f and g firmware.
