i'm attempting to burn my final CD. i have all of the .vob's and can put them into the .mpg. but i have not been able to successfully burn it. I'm using VCDImagerGUI and CD-RWIN but cannot get past VCDImagerGUI when trying to put my .mpg into vcd. my .mpg file size is 2.46 GB. should I be spliting my file so each cd has the 74 minutes on it. or am i able to have the whole movie on the once cd? any help would be very appriciated. thank you
Open TMPGEnc, Click on File, Choose MPEG Tools, Click on the tab Simple Demultiplex. If it's not there, get a newer version. Load up your mpeg and run it. Get bbmpg. Then..
1 Start bbMPEG (avi2mpg2)
2 Click on the [SETTINGS] button.
3 Enable MULTIPLEX VIDEO and MULTIPLEX AUDIO if they are not already
click the [Input and Output files] tab (forget about the max. size, we will do this later)
4 Click on the OPEN PS button to name the output file
5 Choose and output filename and click [SAVE]
6 Click on the OPEN VS button
7 Select the MPEG-2 video stream
8 Click on the [OPEN AS] button.
9 Select the MPEG-1 audio stream [OPEN].
10 Click on the [PROGRAM STREAM] button.
11 Set the [PROGRAM STREAM] to SVCD and then return to the GENERAL SETTINGS tab.
12 Set the MAX size as follows: 74min CD-R : 720, 80min CD-R : 780
After a few minutes, you will have smaller mpg that vcdimager will like.
<font size=-1>[ This Message was edited by: NuebieN on 2001-09-09 19:57:18 ]</font>
problem with mpg format
By volam in forum EditingReplies: 0Last Post: 17th May 2009, 14:31 -
[FFMPEG -> VCD-MPG] How to push CBR?
By Gew in forum Newbie / General discussionsReplies: 4Last Post: 13th Apr 2009, 10:05 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 12:34
