I have two movies made with DVD2one that are 2 gigs each. I would like to put them on 1 DVDR with a simple menu to select the movie to play.
Does anyone know of a program or a way to do this?
Any suggestions would be appreciated.
Chas
Sonic, DVDit, Ulead, Maestro, etc. Basically any authoring program that allows you to make menus. I personally like Maestro, but to each his own. You can find a maestro guide at:
http://www.doom9.org/mpg/maestro.htm -
Thanks for the quick replies.
I believe with the programs mentioned, you have to start with MPEG files. What I want to do is keep the vobs created with DVD2one, without re-encoding, and create a menu.
Is this possible?
Chas -
I am also interested in doing this.
Please post whether or not you had success with any suggestions.
I noticed that Ulead Movie Factory also allows import from VOBS, but it seems to convert each chapter into a separate MPG, rather than have the one MPG stream and automatically mark chapters - sub-optimal in my humble opinion.
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2010, 00:36 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 14:47 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 02:25 -
insignia ns-1dvdr...multi region?!?!?!?!?!??!
By ginouac in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Oct 2007, 02:10
