When i try to convert a file to mpg with TMPGEnc, it gives me this error that says,illegal floatig decimal erro, or something like that. can someone help me and tell me whats wrong and what i should do? thanks.
-Mike
I've gotten that error when the avi file has a bad spot. Look at the time of the error then play the avi file with media player and see if it freezes at the same point. I usually play it with vdub and if it freezes I save it to that point then skip to the next key frame and save to the end in a different file then join the two files.
<font size=-1>[ This Message was edited by: RCP on 2001-09-09 22:27:16 ]</font>
Any current ffmpeg builds floating to the top?
By Calidore in forum Video ConversionReplies: 0Last Post: 11th Jun 2011, 15:22 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 19:41 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22
